“Leoma” update 11/19
Re: “Leoma” update 11/19
Hi Steve, That's kinda of how I was thinking. Hopefully I can trade one of the 25#er CQR's. I wouldn't mind having a Rocna type I seen the videos showing how great they are. Not sure what you mean by the bridle setup. I also have 100' chain and nylon splice to it. Most of the anchorages around here are about 30' sometimes deeper if it's crowded. I don't feel good with only the chain unless it's very calm and under 30'.
Steve Laume wrote: I am also sticking with my wheel, Steve.
LOL. Hilarious!
JD-MDR wrote:Hi Steve, That's kinda of how I was thinking. Hopefully I can trade one of the 25#er CQR's. I wouldn't mind having a Rocna type I seen the videos showing how great they are. Not sure what you mean by the bridle setup. I also have 100' chain and nylon splice to it. Most of the anchorages around here are about 30' sometimes deeper if it's crowded. I don't feel good with only the chain unless it's very calm and under 30'.
Steve L is correct that the CQR is a proven anchor. The Pardey’s used a 35lb CQR on 19,000 lb Taleisin the entire 30’ish years they sailed her which included about 150,000 sea miles. All engineless I might add.
Here is the photo of my old Distribution Panel and the new one. The cabinet door and frame I got from the consignment store turned out to be too small. I had to have the panel in now, so I could install the breakers for the auto pilot and plotter. I'll have to get a better plan for the cabinet and redo it. I did however pull out all the old and useless wires. Now I have mostly new wires all routed nicely and with heat shrink eyelets. I left enough slack so I can work on it later. I also cut a piece off the power feed bar to isolate one position for a 30 amp shore power breaker. I'm not sure if that was a good idea. It's the one on the bottom that's not labeled. The panel is secure and sturdy. I'll think about how to rebuild it for a few months. I want to make that whole corner a perfect cabinet like it was original from the factory. When I got the boat, the cockpit combings were disconnected from the cabin. I drove some longer screws thru that wooden backer piece. This is probably the worst area on the boat as far as carpentry goes. There is a little water damage under the forward portlights and under the companionway. These are not a priority for me.
distribution panal before.jpg (684.54 KiB) Viewed 1637 times
Distribution panal.png (372.93 KiB) Viewed 1704 times
I found a 45 lb. CQR on C= list for $150. It looks like it includes a swivel and some 3/8 " chain. I wonder if its too big for my boat. I know the chain won't work with my windlass. I sold one of my 25lb er's for $100
Screenshot_2020-01-14 CQR Anchor (45lb) chain.png (402.26 KiB) Viewed 1687 times
Be patient, the right anchor will come to you. I feel the 35# CQR with 5/16" chain, is the right size for a CD-30. Anchor size is kind of like Goldielocks' porridge.
Craig's list is great but I have recently found that Facebook Marketplace is more popular. You could also look for a local consignment shop. Anyone trying to fit out a boat on a budget should find a consignment shop. They have things you didn't even know you needed, Steve.
Thanks Steve, The consignment shops have a couple 35's but not good condition and they want to much. I'll wait and maybe work will pick up and I will afford a claw type
I agree with Steve that a #35 is about right. If you go with a CQR make sure it’s a genuine CQR and not a knock-off. I have purchased a couple key items from consignment shops. I never paid the asking price.
jbenagh
Salem, MA
Post by jbenagh »
I agree with them as well. I've used same setup Steve described for almost 10 years with my CD30.
Jeff
Do you have worm drive steering? Mine has a little slop in it. I was told its not bad though. I might send the whole shaft assembly into Edson for a tune up. They recommend sending the whole unit in because it all has to work together and I shouldn't just replace the one part. The guy (I forgot his name) in charge of worm gear dept. said he was with quality control at Cape Dory.
My wheel is pedestal mounted with a cable drive. The worm drive seems more reliable but less convenient to me. I usually only hand steer when doing some sort of maneuvers where I like the fact that I can stand up while holding on and still steer the boat. While your worm drive may be a little sloppy it is not apt to fail the way a wire drive system could. That rebuild by Edson is not going to be cheap, Steve.
Walter Hobbs
Post by Walter Hobbs »
Hi Steve,
I need to rewire the rats nest on my CD 27. Could you post a few photos of the interior details of your distribution panel wiring?
thanks
Walter R Hobbs
CD 14 hull # 535, Grin
CD 27 Hull # 35 Horizon Song
Lincoln, RI
moctrams
Post by moctrams »
This the wiring job for Gabbiano.
NAV STATION OPEN.JPG (1.68 MiB) Viewed 1649 times
NAV STATION FRONT.JPG (174.42 KiB) Viewed 1649 times
Frenchy
Post by Frenchy »
That's impressive, Moctrams. :!: Did you do it yourself? It sure looks professional.
moctrams
Post by moctrams »
Did it myself. Retired telephone Co. I have rewired many boats over my 30 years at Flag Harbor in southern Maryland. Owner buys all the "stuff" and I only charge labor. The max I ever charged for labor was $1500.00. It's all fun anyway.
Gabbiano power.jpg (119.32 KiB) Viewed 1640 times
