Installing Taller Off-Shore Stanchions
Most boats under 40’ built during the era of our Cape Dories all seem to have 24” tall stanchions. I have always felt 24” is too low for offshore sailing...especially if you find yourself on the lee side. Though I managed with the original stanchions just like everyone else I alswys wanted to upgrade them to 30 inches. I finally tackled the project this past week. I have not sailed with them yet but just being on deck feels much safer. Couple pictures below. Click on the link for the details of the installation. Total cost for the heavy duty brass tubes and solid bronze top fittings from Port Townsend Foundry was $840.
https://wordpress.com/post/farreachvoya ... s.com/1267
- The new stanchions have a sidewall twice as thick as the stock stanchion and are 30” tall.
- 0263087F-894F-4841-9274-13B2222BC4AF.jpeg (831.63 KiB) Viewed 1025 times
- The brass tubes will change color to a burnished bronze brown matching the gallows frame.
- E62C9E21-CAD0-4C7C-9A02-560526F39425.jpeg (772.59 KiB) Viewed 1025 times
Re: Installing Taller Off-Shore Stanchions
The brass stanchions compliment the boat well.
I have also thought that 30" stanchions were more functional.
Hope to paint and install these composite brackets next year.
Will use 30" x 1 1/4" FRP rods for stanchions. Still need to decided on a material for bulwarks.
Hi John
Regarding the dodger installed on S/V Far Reach, do you have instructions on how your made it or where did you buy it??. Would like to install something similar on my CD25D-Juno. Does it has ss tubes?? By the way, stanchions look awesome...
Carlos
Carlos
Hi Carlos. Thanks. Glad you like it. Smase it myself. Super simple. Uses black irrigation tube I purchased at Lowe’s. Four pieces of UHMW plastic and some shock cord. The material is stamoid. You simple push it forward to make entering and leaving easier.
- F29F46E6-59F6-4432-A1A0-C3F3BB7A92F2.jpeg (1.54 MiB) Viewed 985 times
- 6D20B803-5202-4917-BED3-3AA4A5E43AF8.jpeg (1.67 MiB) Viewed 985 times
Thanks for the information John.
Carlos
Carlos
Hi again John
Looking at the pictures of the dodger, how do you hold it still on top of the companionway while navigating??? Is it screwed to the wood???
I would appreciate it your response
Carlos
Carlos
Carlos, I cut a piece bronze about 4” long and 3/4” wide and secured it to the end of the irrigation pipe with a couple 1/4-20 fasteners. Then, I secured the pivot point to the bronze insert I installed into the teak with a 1/4”-20 machine screw. See the link and scroll down to the part of the pram hood.
I’ll try to take a picture if I can tomorrow or the next day.
http://www.farreachvoyages.com/projects/wrinkles.html
Ok John, will wait for the photos. I like your dodger design a lot, doesn't take much space, and will look good on Juno.
Carlos
Carlos
Two photos below how the ends of the hoop fit into the bronze inserts I set flush in the teak rails. The picture of the insert is in the link I provided above.
- 858BD1EA-DEBF-4707-AE80-7485B948327A.jpeg (1.48 MiB) Viewed 963 times
- 70087052-72F0-4187-8FA8-17097B5051EA.jpeg (1.54 MiB) Viewed 963 times
Hi John
Thanks for photos.
Much appreciated.
Carlos
Thanks for photos.
Much appreciated.
Carlos
