This is a longshot, but does anyone have any ideas on how I could research the name given to my '76 CD28 (Hull #91) by her original owner. I've exhausted the most obvious avenues, like back tracking prior owners, but, unfortunately, I do not even know the name of the original owner at this point.
ekramer@mailbmc.com
Tracking original name of boat
Re: Tracking original name of boat
Hi,
Here in Canada we have a site from the Coast Guard.
The link is:
http://www.tc.gc.ca/ShipRegistry/advanced.asp?lang=e
Probably you have the same in the US
You could try it.
Marc
A22 #275
adrenaline@vif.com
The link is:
You could try it.
Marc
A22 #275
Evan Kramer wrote: This is a longshot, but does anyone have any ideas on how I could research the name given to my '76 CD28 (Hull #91) by her original owner. I've exhausted the most obvious avenues, like back tracking prior owners, but, unfortunately, I do not even know the name of the original owner at this point.
adrenaline@vif.com
If the boat's not documented, then there won't be any gov't records of the name.
Do you know where the boat was moored? It's also a long shot, but a marina might have records. Or there might be someone with a very long memory.
Regards, Neil
neil@nrgordon.com
Regards, Neil
neil@nrgordon.com
If it has been documented, you can go to http://www.st.nmfs.gov/commercial/landi ... ssel2.html
to put in a query.
Ed Haley
s/v Mokita
CD330 #1
On the hard in Clayton, NY
eghaleyNOSPAM@twcny.rr.com
to put in a query.
Ed Haley
s/v Mokita
CD330 #1
Hi Evan, Here is a longshot you might try. Do you have any idea what state it came from? If it wasn't documented, the craft was probably registered with the Dept. of Motor Vehicles in that state. Here in N.Y., if the vessel has a motor in it, it has to be registered, including the hull number. This might break the log jam and tell you the name of the owner in that year. It might be worth a shot. Good luck. John Dunn, Ty #42? Oswego N.Y., E.end of Lake Ontario
Choppedliveroy@aol.com
If it was/is documented, you will need to go to the Coast Guard Documentation Center and request an Abstract of Title. It will list all previous owners. Cost was $25.
Checking this site, search by name, may help and it is free:
http://www.st.nmfs.gov/st1/commercial/l ... ssel2.html
dennis.driscoll@roche.com
