gelcoat
Charlie Palumbo
gelcoat
Post by Charlie Palumbo »
As I soon will be repairing some minor deck gelcoat crazing, would anyone know where to purchase matching tan gelcoat? My intention is to mix the gelcoat, the hardener and west system 406 (similar to cabasil) to make the repair.
Thanks.......Charlie
jcp1347j@aol.com
Ron Musk
Re: gelcoat
Post by Ron Musk »
Charlie Palumbo wrote: As I soon will be repairing some minor deck gelcoat crazing, would anyone know where to purchase matching tan gelcoat? My intention is to mix the gelcoat, the hardener and west system 406 (similar to cabasil) to make the repair.
Hold on Charlie,
You had best check to be sure gelcoat and epoxy are compatable for cosmetic repairs, I don't think they are.In any event widen the cracks to a v shape before filling--Scandvik makes a nice carbide scraper that works perfect for this.A search in the archives will give the gelcoat manufacturer that can match any color,I can't recall their name.Good luck.
Ron
CD30c
s/v "R&R"
Larry DeMers
Re: gelcoat
Post by Larry DeMers »
Gel coat and epoxy should be compatible with each other..I am missing your caution here..could you elaborate please?
The Gel Coat itself is available from:
GCPI or Gel Coat Products Inc.
P.O. box 17336
11090 N.W. 52nd
Seattle, Washington 98107
Phone number 206-781-1162
The color is Custom Beige with wax..#53097
Cheers,
Larry DeMers
s/v DeLaMer
Cape Dory 30
Hold on Charlie,
Ron
CD30c
s/v "R&R"
demers@sgi.com
Ron Musk
Re: gelcoat
Post by Ron Musk »
Larry DeMers wrote: Gel coat and epoxy should be compatible with each other..I am missing your caution here..could you elaborate please?
P.O. box 17336
11090 N.W. 52nd
Cheers,
Larry DeMers
s/v DeLaMer
Cape Dory 30
Hold on Charlie,
Ron
CD30c
s/v "R&R"
Polyester gel coats are not usually used as a finish to epoxy repairs without the recommended additives for that system.While not having experience with the use of these additives I can say that (although my memory may not be what it used to be) it is always prudent to ensure different products compatability and do the job once.
Ron
ccerre@rcn.com
