head holding tank CD28
Dean Smith
Post by Dean Smith »
Was the Cape Dory 28 produced with a head holding tank? If so, what size is it and what material is it made out of? Is the head designed to discharge directly overboard as well as into a holding tank?
-Dean Smith
dean@starboardtack.com
Paul Scribner
Re: head holding tank CD28
Post by Paul Scribner »
Dean Smith wrote: Was the Cape Dory 28 produced with a head holding tank? If so, what size is it and what material is it made out of? Is the head designed to discharge directly overboard as well as into a holding tank?
-Dean Smith
Dean: I can only guess at the original configuration but, as you know, a direct discharge(or Y-valve) from the head is a no no and the CG will assume you are a bad guy if they find it. I re-fitted my 28 Serenitas with a thirty-gallon tank and a Y-valve after the tank going either to the deck pump out or (when legal) to a overboard discharge.Seems simple enough compared with the bowl of worms I inherited. Happy Sailing. Paul
scribner@tiac.net
Warren Moore
Post by Warren Moore »
-Dean Smith
Paul,
Where did you put the 30 gallon holding tank on your 28? How big a job was it to install? Warren
w.moore@juno.com
