25D Cabin Sole and Lead Keel Questions
Bill
Post by Bill »
Hello to All
I was wondering if anyone has ever removed the cabin sole of their boat. I would like to add some stowage beneath the sole and would be interested in knowing if the sole was glued to the fiberglass pan that is below it. I think it is (glued), but cant tell for sure.
Secondly, At some point in the future I will be adding a Ham radio to my boat. On the Icom site Gordon West suggest drill and tapping into the lead in the keel (from the bilge), leading a strip of foil and bolting it to the keel to use as a counterpoise. Any thoughts about drilling the Keel????
Bill
cd25d@rhapsodysails.com
Steve Alarcon
Re: 25D Cabin Sole and Lead Keel Questions
Post by Steve Alarcon »
Bill,
On my CD36 the strip of copper foil is attached to the inside bolt of the grounding plate. I presume that Cape Dory used the same grounding scheme for all of the models.
Steve Alarcon
CD36 Tenacity
Seattle
alarcon3@prodigy.net
Bill
Post by Bill »
Steve Alarcon wrote: Bill,
Tnx Steve
I am aware of the use of the dyna-plate for counterpoise, but West asserts that by using the lead in the keel, even though not actually exposed to saltwater, creats a great counterpoise.
I am just wondering if anyone has tapped and drilled the keel for this purpose?
FW
Bill
Steve Alarcon wrote: On my CD36 the strip of copper foil is attached to the inside bolt of the grounding plate. I presume that Cape Dory used the same grounding scheme for all of the models.
Steve Alarcon
CD36 Tenacity
Seattle
Don Sargeant
Post by Don Sargeant »
Coquina's cabin sole seems to be screwed down -- at least it has some plugged holes in it.
Don Sargeant
CD25D #189 etc.
Bill wrote: Hello to All
Bill
Kevin Mulligan
Post by Kevin Mulligan »
I just pulled up the cabin sole on my CD 28 as it was delaminated. Removing all the screws (about 10 from the top and 12 from the bottom) did no good as it was held down with adhesive. It came apart as I pulled it up. I'll consider putting the new teak and holly down without as much adhesive.
Kevin Mulligan, Skibberreen, CD 28, #226
Don Sargeant wrote: Coquina's cabin sole seems to be screwed down -- at least it has some plugged holes in it.
Don Sargeant
CD25D #189 etc.
Bill
kmulligan@yahoo.com
Bill
Post by Bill »
Thanks Kevin
Folowing my posting I did a bit more investigation and found the fiberglass "subfloor" you found. I assume that it is bonded and as my sole is in good shape, thats one chore that will not be happening anytime soon.
Bill
Kevin Mulligan wrote: I just pulled up the cabin sole on my CD 28 as it was delaminated. Removing all the screws (about 10 from the top and 12 from the bottom) did no good as it was held down with adhesive. It came apart as I pulled it up. I'll consider putting the new teak and holly down without as much adhesive.
Don Sargeant
CD25D #189 etc.
Bill
