I am the happy new owner of a '75 weekender. The boat has had a bow pulpit installed. There are three s.s. plates (attached with two screws) running down each side near the toe rails, which have an internal spring clip and about 1/4" opening, for what I assume were once some type of light weight stanchion. However, no stanchions came with the boat. Anyone know anything about these? Thanks. Bill
wdj1@top.monad.net
typhoon weekender stanchions
Re: typhoon weekender stanchions
It is timely you posted this message, for I was about to ask just the same thing. My 75 Ty has three stainless steel Schaefer fittings on each side -- each is just the one piece of metal, so I am curious about the spring clip you mention. I also assumed they were for supporting lifeline stanchions, but I have not seen a Ty so rigged. Anyone have a picture with A Ty with these stnachion mounts used as such?bill wrote: I am the happy new owner of a '75 weekender. The boat has had a bow pulpit installed. There are three s.s. plates (attached with two screws) running down each side near the toe rails, which have an internal spring clip and about 1/4" opening, for what I assume were once some type of light weight stanchion. However, no stanchions came with the boat. Anyone know anything about these? Thanks. Bill
dspauld@javanet.com
