Seacocks revisited
Bill
Seacocks revisited
Post by Bill »
Hi All
Well I got the seacocks lapped/lubed, but I screwed one of them up and had to replace it (gotta love the learning curve). Anyway, I had to buy ONE new one and the bronze screws that attached it to the thru-hull were orginial (sp) and got really boggered up when I pulled them out. So NOW where do I find re-placements (remember this is Oklahoma)???? I am not too sure as to their size, but I would guess either a 3/16" or a 1/4" (I would guess the former & will make sure prior to ordering), by 3". Were do I get bronze bolts/screws???
Bill
Being on the hard really sucks!!!!!!!!! Hats off to the northern brethern who endure so much (winter) for so little (short season)...
cd25d@rhapsodysails.com
Joe Mac Phee
Re: Seacocks revisited
Post by Joe Mac Phee »
Bill,
Try Jamestown Distributors in Bristol RI. www.jamestowndistributors.com.
jvmacphee@aol.com
Russell
I'm about to go through same process. Perhaps you can answer
Post by Russell »
Are the bolts round-head? (From the inside, I can see only their tails. Until the boat is out of the water, I have no way of knowing what kind of bolts they are. And I'd like to order them beforehand.)
Scott Ritchey
Post by Scott Ritchey »
If you have time for mail order, check Southern Crown Boatworks (http://www.southerncrownboatworks.com/), near Atlanta.
Also, re a subsequent posting, they are normally flat head slotted with a countersink into the glass hull.
Bill wrote: Hi All
Bill
ritcheyvs@aol.com
Scott Ritchey
On second thought, I got my last set of bronze machine screws from Chesapeake Marine Fasteners (http://www.chesfast.com/, 800-526-0658). I used the 800 number and they didn't seem to mind the small order (3 screws/washers/nuts).
Scott Ritchey wrote: If you have time for mail order, check Southern Crown Boatworks (http://www.southerncrownboatworks.com/), near Atlanta.
Bill wrote: Hi All
Bill
Bill
Post by Bill »
The screws from my boat are 1/4x24x3" Flat head slots (Bronze).
bill
Russell wrote: Are the bolts round-head? (From the inside, I can see only their tails. Until the boat is out of the water, I have no way of knowing what kind of bolts they are. And I'd like to order them beforehand.)
Scott Sirgo
Post by Scott Sirgo »
Try Mc Master Carr @ mcmaster.com then place orders at (404) 346-7000.It is well worth visiting the site, they have almost everything. I just purchased silicone rubber hose for my raw water exhaust manifold to dry exhaust hose (rated +350 deg. f.)#5296K31. This is about as one-stop shopping as you can get. The paper catalog is over 3000 pages so set aside some time and enjoy. Hope this helps.
