Typhoon Mast pin/hole question
CentralCA0ceaNut
Post by CentralCA0ceaNut »
On the base of my Typhoon Weekender mast, the stainless steel pin has worn the aluminum mast hole. One side is worse than the other, see images. I was planning on JB welding SS fender washers on either side of the mast to reinforce the pin.
My question is what shape was the hole originally?
It looks like there may be some engineered play to allow raising of the mast. Does anyone know this information or have pictures of there mast hole that isnt as worn?
Ryan
