While organizing some of our events this summer, we came across a lot of incomplete information in our membership database. Please go to the CDSOA Home Page in the banner at the top of this page and login. Once you are logged you will see Membership Directory. Search for yourself and check to make sure the information is current and is complete. Or you can follow this link. https://capedorysoa.org/content.aspx?pa ... _id=432709
Make sure you login first. You will not see the Membership Directory if you are not logged in. If you forgot your login credentials, You can select a new password.
CDSOA Members - Update Your Membership Information
Sir Isaac Newton
Sir Isaac Newton
Re: CDSOA Members - Update Your Membership Information
Hi Carl,
Thanks for posting that. I signed in and then clicked on the link.
I searched for my name and saw very limited information.
When I clicked on the contact card file, I again saw very limited information.
Maybe I missed something. I'm still not sure how to check or update my info.
Ken
Ken
Ken Easley
Intrepid 9 Meter - Felicity
Southport Harbor, Connecticut
Hi Ken,
Click on the area in Red, not the V-Card in yellow. If you click the V-card, you will only see what information is already entered. Oh, and make sure you scroll down the page.
Sir Isaac Newton
Sir Isaac Newton
Once you get in to edit your member profile, you can navigate through the various fields either by scrolling down the page and filling in each field or you can toggle through them using the blue highlighted text on the right side of the screen that I have circled in red in the photo below. Make sure you check the "edit" pencil on the right side of each screen. And yes, you can add banner photos and a member photo. Get as creative as you like.
Sir Isaac Newton
Sir Isaac Newton
The edit tool is circled in red in the photo below.
Sir Isaac Newton
Sir Isaac Newton
Thank you. That worked.
Ken Easley
