Some of the work that I have done requires additional modifications to accommodate.
- The hawse pipe has moved aft with the addition of an anchor windlass. I'm planning to put in a length of PVC pipe to quide the chain to the bottom of the boat. This will probably require cutting away a bit of the liner and creating some kind of containment.
- The standing rigging has been resized. The bolts, tangs and wire are all larger. I would like to add a compression post to take some of the load off the original deck and bulkhead structure.
- No toilet, but there isn't really a galley so these may cancel each other out.
Also, I would like to purchase used 5/16" BBB anchor chain. Please let me know if you know a source.
Jonathan
