CD 30 prop size?
Bob Ohler
CD 30 prop size?
Post by Bob Ohler »
I have a CD30B with a Universal M18 engine. It currently has a Michigan Sailer 13 x 8 right-hand prop. It has never motored much faster than 5 knots. As I’m now looking at the pic I took of it today, the “8” appears to be stamped over “10.” For the first time, as I’m looking at the pic, I’m now thinking the original prop was originally a 10 pitch and was re-pitched to 8. Does this make any sense to any CD 30 owners? And to other CD30 owners with the Universal M18, what prop are you turning?
Bob Ohler
CD30B #335
Bob Ohler
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
S/V Ethan Grey
Re: CD 30 prop size?
Post by S/V Ethan Grey »
Hi Bob,
I have a Cape Dory 30 with a Volvo MD7A. It looks like the M18 is a 14HP motor, very similar to my Volvo MD7A 13HP. I recently bought a Campbell Sailer, 3-blade propeller. It is 13” with an 8.5 degree pitch. I get a little over 5 knots when pushing the engine near 85% maximum RPM. Props can be repitched if necessary.
I would contact West by North (https://westbynorth.com/campbell-sailer/) and see what they have to say. They are excellent and Kelsey was very helpful.
David
S/V Ethan Grey
1981 CD 30C, Hull #199
Niceville, FL
CDSOA# 1947
Skipd
Post by Skipd »
Hi Bob,
I too have a 30B with the Universal M18. Purchased the boat in 2021 and am confident the prop is the original. It was reconditioned by H&H this past fall and shows it is clearly a 13 x 10 RH, 1” shaft. With a clean bottom etc the boat easily cruises 5.5 knots at about 2200-2300 rpm and burns about 1/3 gph.
Skip
