I realize (and have asked before) about 25kt+ winds. I realize that it's unrealistic to expect any forward progress in those conditions in a 25D, and that trying would be "trying" to put it gently.
So... I'm wondering what's the best strategy with a 150% furling genoa on this kind of boat (25d) for beating into 15-20 kt winds and 4-7 ft waves, where I might expect (but haven't been able to achieve) reasonable performance? In my area waves like that are typically about 20 ft apart and steep.
Here's what I've tried:
- Leave everything up. This puts the rail deep in the water and requires me to luff the main with each gust. Uncomfortable sailing at about 2kt VMG, and I assume I'm ruining the sails.
- Furl genoa down to 100% and reef main once. Foresail shape is awful. I get about 2 kts VMG while tacking across 125 deg.
- Leave genoa full and reef main twice. Still feels over-canvassed and I get lee helm. Didn't sail long enough to establish VMG, but I'd like to try again just to see. I've heard lee helm is no good upwind because it gives the rudder reverse lift.
- Raising the 100% jib unstayed on an extra halyard. I'm assuming it would perform worse than a jib on the stay, but maybe better than the furled genoa.
- Creating an extra dyneema "stay" by running a line from the masthead through a snatch block mounted behind the forestay. This would give me something like a cutter rig, and I'd only tension the "stay" when in use. Then I'd raise the 100% jib up this "stay" with an extra halyard.
- Putting a couple swim noodles around the forestay (as high as I can reach) before I furl to take out some bagginess.
