Datamarine Corinthian Instruments (**Sold**)
Skipd
Post by Skipd »
Full set of Datamarine instruments removed from 1986 CD30.
> Corinthian Series LX-360 Wind Machine w/cables ***no masthead transducer***
> S-200DL L.C.D. Digital Depth Sounder w/transducer and bronze thru-hull
> S-100KL L.C.D. Digital Knotmeter w/bronze transducer and fairing blocks
> A-181 Log/Control Panel
Each instrument is complete with display, retaining collar, cover, cables, transducers (except wind), hull/mast fittings, manuals, retaining pins, speedometer plug, depth fairing blocks, retaining clips.
Wind cable was new and approximately 80 feet long and had been cut at about the 40 ft point.
Instruments were working on the CD30 and then tested when removed. Testing involved making cable connections and supplying power. Wind and speed operated as expected (masthead unit has sold since testing). Depth powered up and gave misc. readings but the transducer was not in water.
These were on a fresh water boat and corrosion is minimal. They were replaced in a general electronics upgrade.
Make an offer, either for the lot or for an individual set.
Happy to answer any questions. Thanks
S/V Ethan Grey
Re: Datamarine Corinthian Instruments (wind, speed, depth, l
Post by S/V Ethan Grey »
Hi there,
I am interested in these for my CD30. I really would like the depth sensor display as mine has deteriorated. However, the whole kit would be a welcomed addition. Would you mind instant messaging me with how much you're looking to get for the whole set? I'll PM you a message as well
David
David
S/V Ethan Grey
1981 CD 30C, Hull #199
Niceville, FL
CDSOA# 1947
