replacement for Simpson Lawrence anchorman power 700 windlas
Jbodkin
Post by Jbodkin »
Greetings, I have a simpson lawrence anchorman 700 windlass on my 1982 CD 36 (#69) that needs replacement (cracked gear housing and frozen shaft). Does anyone have recommendation for a replacement windlass that will utilize the existing Simpson Lawrence mounting template, or experience/advice for replacing the existing mounting block. Attached is a photo of the existing mounting block. Thanks for any and all replys. Jim
Paul D.
Re: replacement for Simpson Lawrence anchorman power 700 win
Post by Paul D. »
The deck template looks similar for the Lewmar V2 windlass I installed on our 33 a couple years ago. I've had good results using this with an all chain rode and the installation looks really clean and simple on the foredeck. I will see if I can find a picture to add when I am not procrastinating work...
Here's the installation manual link; see if the measurements are close. Good luck.
http://www.ironbarque.net/Boat%20Docume ... manual.pdf
