What is the typical price for a bottom paint job?
I'm in Texas, and I need the old bottom paint removed, and new coats applied.
Excluding the price of the paint, what is the labor cost for a CD27 approximately?
Anybody have recent experience?
Would it include painting a new waterline stripe?
Thanks. I'd appreciate a sampling of costs across the country.
Bill
Typical price for bottom paint?
Re: Typical price for bottom paint?
If you haven't had a barrier coat installed under your bottom paint, this may be a good time to do it. Costs quite a bit more, but if you roll on the 6 or so coats yourself (after having the bottom stripped and sanded) it will keep costs down.
Cheers!
Cheers!
Jennifer & Terry McAdams
Kearsarge, New Hampshire
Mahone Bay, Nova Scotia
CD 31 #33 "Glissade"
barrier coats are dependent on the bottom being bone dry. any moisture in the fiberglass will produce blisters in the epoxy later on.
Just had my cd25d hauled out of lake grapevine, Texas . Cost of bottom job estimate arm$2200
$75/ ft +2gallons interlux. Bottom looked good after 6 years in fresh water
