Spartan port light gaskets
Bmcartjr
Post by Bmcartjr »
Spartan port light gaskets needed
Re: Spartan port light gaskets
This recent posting has all the info you may want. Feel free to ask additional questions.
http://www.capedory.org/board/viewtopic.php?f=1&t=36137
Vincent
Post by Vincent »
Scraping the old gasket or is a time consuming job. I found a small brass tool in my dads workbench that works very well. Without that, I would get a sturdy stainless dinner knife and use a grinder to round it off to fit the diameter of the port where the gasket goes. Sand it down, you don’t want any burrs.
Once the old gasket is scraped out, I cut the McMaster gasket a bit long, and then I apply contact cement to the gasket and the port. When dry,
Carefully lay in the gasket around the port, I start at the top, and finish at the top. I angle the cut, and pull it a bit to stretch it, make the cut with scissors and squeeze it in. So far, no leaks. The old gasket was pretty hard and needed replacing.
barfwinkle
Post by barfwinkle »
A wire wheel in a drill works really well.
HNY
Bill Member #250.
Nebe
Post by Nebe »
a little silicone grease can extend the life of those gaskets tremendously.
