Installing air conditioning unit in Cape Dory Daysailor
Sea Hunt Video
Post by Sea Hunt Video »
I recently purchased a 1980 Cape Dory Daysailor (open cabin model). I live in Miami. As everyone knows it is very hot. I would like to install an air conditioning unit in the Daysailor. I would like recommendations on what make and model of a/c unit I should install. I have heard good reports about the Marine Air 16000 BTU unit. I am especially interested in recommendations on BTU size since it will be used mostly in hot and humid Miami.
I would also appreciate recommendations on where to install the a/c unit so as to maintain proper trim and balance.
Thanks :!: :D
Ben Miller
Re: Installing air conditioning unit in Cape Dory Daysailor
Post by Ben Miller »
I think I've got just the thing for you, Roberto. Weight trim isn't an issue, and if the wind dies, you can make your own!
I have no personal experience installing air conditioning on a day sailor but it is an interesting proposition so I will be closely following the recommendations of our more knowledgeable members. :roll:
Steve Kuhar
Pensacola, Fl.
Post by Steve Kuhar »
Roberto,
If you install the unit well forward you can maintain proper trim by installing dinghy davits on the stern.
Steve Kuhar
Steve Kuhar
Pensacola, Fl.
Roberto,
Upon further reflection about your problem of how to keep cool while sailing in Miami, I was reminded of a similar problem in which one of our members who was fishing our northernmost waters in the native traditions was looking for suggestions on how he might stave off the cold, and it was suggested by members of this forum, that if he were to build a small fire in the bottom of the boat it would at least keep his feet warm. Unfortunately, when he tried to act on this suggestion the entire boat went up in flames and he lost everything.
This lends credence to the old adage that "You cant have your kayak and heat it too."
Steve
Forrest
Post by Forrest »
Have you considered making a one piece drop board and cutting a hole big enough to install a small window unit - I've seen this work on a CD 36.
https://www.amazon.com/dp/B06WRRZLYB?aa ... 8680510301
Forrest Paddock
Houston, TX
Supporting this site through membership in the CDSOA, Inc. Member 420
Oswego John
Post by Oswego John »
Hi Roberto,
I wish you a "Happy April Fools Day", too.
Think Spring,
"If I rest, I rust"
Voting Member #490
mgphl52
Post by mgphl52 »
Hi Roberto,
Please excuse my tardiness in replying. After studying the problem in depth, I believe you can avoid extra holes in the hull and expensive wiring & plumbing costs, not to mention the expense of a reefer unit itself.
My suggestion is that you arrange a contract with a local ice house to deliver a cockpit load of crushed ice to your nearest fuel dock early every morning that you wish to sail. Then you can simply "slide" into the cool and go sailing.
Most likely, by the time the ice melts, you'll still be numb and not feel the heat.
Hope this helps!
Skylark
Post by Skylark »
I have no experience with this alternative. However, it is the only 12v (or 24v) air-conditioning unit I have found for marine use. It is also very expensive. Though, they did try to sell me an older unit at about half price.
http://www.cruisencomfortusa.com/marineseries
mashenden
Location: "Nautica" CD-36 #84, Ty-K #83, & CD-10 #1539 in Urbanna, VA. 4 other Tys in past
Post by mashenden »
By far this is the best boat air conditioner for a Daysailor. As you can see I installed one in a Typhoon Daysailor last April 1st. Wow, was it ever cooool!!!!
Warning: if the setting is too cool, you may experience tattered sails.
Matt Ashenden
- I used to like boating and fixing stuff, then I bought a couple of boats and now I just fix stuff :)
