Water coming up rudder shaft tube.
jeffb
Post by jeffb »
Recently purchased a CD28.
It appears that that the stern lays deeper in the water, below the waterline, while under power.
As a result water splashes/trickles out the rudder shaft tube.
Anyone have any thoughts on the cause and/or solution.
psjanker
Re: Water coming up rudder shaft tube.
Post by psjanker »
My 28 does the same thing. One could always put in a drip less on the rudder shaft but I keep storage forward. CD 30 has a packing similar to the prop shaft.
V/r
Pete
Joe Myerson
Post by Joe Myerson »
After I had my new prop, shaft, motor mounts and cutless bearings installed and I took Creme Brulee for a test run with the engine wide open, I noticed the same thing. It is apparently normal.
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
fmueller
Post by fmueller »
my 27 does this too, mostly under power - it's not a lot of water - barely enough to get to the scuppers
Fred Mueller
Jerezana
CD 27 Narragansett Bay
psjanker
Post by psjanker »
After recore'ing my cockpit I left the teak plate off the rudder post...I liked the look better and didn't want to keep refinishing it due to water splashing on it. Not much water and I get it only under certain conditions...heavy weather and following seas most generally.
V/r
Pete
Neil Gordon
Post by Neil Gordon »
As Joe said, it's normal when motoring. I've never noticed it otherwise.
rschlomann
Post by rschlomann »
Happens on my 28 always under full throttle. Thought it might be because of the heavier Md2B engine and 3 blade prop.
