For my CD22...
I've picked up a Forespar tiller extension - have used them on other boats and find them very good.
My question is the CD tillers in general seem quite small/thin compared to other boats - at least the Typhoon and CD22 tillers...
At any rate, I have to drill a 7/16" hole thru the tiller for mounting - this is probably more a carpentry question than anything else - but I'm trying to determine how far back to drill the hole in order to ensure structural integrity of the tiller after the hole is drilled. The tiller isn't that wide and I believe drilling about halfway down is probably safest bet. I would think leaving a 1/2" on either side of the hole would not be an issue. I could of course after mounting the socket - reinforce the area with some decorative rope work.
Forestar tiller extension mounting question
______________
Rick
1984 CD22
Rick
1984 CD22
Re: Forestar tiller extension mounting question
Hi Rick,
Instead of drilling through the tiller to insert the socket, what about rigging the socket to a clamp that you can fasten to the tiller?
Then you don't compromise the integrity or beauty of the tiller. Line the I.D. of the clamp with something soft to keep it from gouging the wood, but grippy enough to stay put when wet.
something like :
![Image](http://www.accuglassproducts.com/images/P/202225_001.jpg)
something like :
a sailor's joys are as simple as a child's
Halfway down would likely leave the extension at an odd angle to your seating position, and would more than double the effort required to hold against weather helm.
Much like drilling a hole in the web of an I beam, a hole in the center of the tiller weakens it much less than you'd think.
Put it where your seating position dictates and it does not lie under hand while steering normally. Locating it forward of your normal grip will minimize any weakening. A blind hole is OK too.
