Hull liner cut out and support tabbed in. Note the hole cut in the long brace- that is for the drain hose:
![Image](http://i1185.photobucket.com/albums/z353/JeffDaigle/CD33/8444BBF5-2043-4E98-9756-31F4980139D3.png)
Box test fit. Rear outboard corner is cut out to allow for curvature of the hull:
![Image](http://i1185.photobucket.com/albums/z353/JeffDaigle/CD33/777B7802-154E-4A6B-A19A-62EBD9DF5A4C.jpg)
Box installed, lined with fiberglass and painted. The hole is actually a marelon through-hull that was flush fit and glassed over. It leads to an acid resistant hose then to a valve mounted high in the bilge so the box can be drained into a bucket if there is a leak:
![Image](http://i1185.photobucket.com/albums/z353/JeffDaigle/CD33/FB8E8641-A19E-49C6-A1C9-AC63DC49B6F8.jpg)
Batteries test fit:
![Image](http://i1185.photobucket.com/albums/z353/JeffDaigle/CD33/9439F6A7-8E9F-4424-824E-539367BC1398.jpg)
The quarter berth had to be raised 3" to allow for the height of the 6v batteries and to provide a small amount of clearance. The box itself serves as support for the berth at the new height. The rest of the plywood panel had risers attached:
![Image](http://i1185.photobucket.com/albums/z353/JeffDaigle/CD33/F95CD1F4-E905-4022-B4F8-DFD7905EB4B4.jpg)
The old access holes aren't in the best location when combined with the new cutout, but the panel is still plenty stiff and doesn't seem to need additional bracing:
![Image](http://i1185.photobucket.com/albums/z353/JeffDaigle/CD33/E7D5AC6C-83EC-4168-9847-6A30089AEA2C.jpg)
Overall, I think we'll be happy with the new bank and the access the new location provides for battery maintenance. There are still a few tasks left to do like make a lexan cover and install a venting system. Wiring the batteries is obviously high on the list. This is a very doable project if you spend some time planning it out. The new height still allows for a comfortable sitting position at the nav station and it doesn't look out of place.
