SOLD -1978 Cape Dory Typhoon Weekender $4500
Located in Chattanooga, TN - LOA 18' 6" Draft 2' 7" Displacement 2000 lbs. - includes main sail with cover, 110 jib, like new complete set cockpit and cabin cushions, anchors, lines, jackets, pulpit (not on boat), 2 hp Honda long shaft with less than 25 hours, 44 lb. thrust MotorGuide electric motor and trailer with tongue extension and two new tires and wheels that will be put on when boat is sold. Boat has been out of the water under cover for the past 8 years. Boat is in very good condition with fresh bottom paint. Pictures are recent.
- IMG_3456.JPG (1.36 MiB) Viewed 704 times
- IMG_3467.JPG (702.83 KiB) Viewed 704 times
- IMG_3470.JPG (757.97 KiB) Viewed 704 times
Re: 1978 Cape Dory Typhoon Weekender $4500
Interesting companionway drop board. Is it one piece, two, nine?
Jim,
..Thanks for your inquiry. It is nine piece.
Is wood all original. Any past core problems. Wi trailor travel 500 miles. Thx, Jim Gregory. Jimgregory@cox.net
Jim,
Thanks very much for your inquiry. I have owned the boat for almost eleven years. It was in the water two or three summers for approximately four months each summer and experienced no core problems.
Also, I know of no blisters in the hull or cabin compression. The wood appears to be original but I have no
way of confirming that.
With the two new tires and wheels on the trailer I would not hesitate to pull the trailer 500 miles. The trailer lights work and it pulls straight.
If you have other questions please email or call me at 423-400-3406.
Thanks for your interest in my Cape Dory and have a good day.
Tom
Tom
Re: SOLD -1978 Cape Dory Typhoon Weekender $4500
Hi Tom,
Did you sell your weekender?
