West System Example 8, page 89
hilbert
Post by hilbert »
Here is my attempt at following West Systems Example 8, on page 89 from http://www.westsystem.com/ss/assets/How ... enance.pdf
Filling a hole below the water line on both sides of the hull with a 12:1 bevel, while minimizing the repair area.
Gluing an epoxy puck in the center of the hole:
Grinding back the laminate:
Fiberglass patches on outside of the hull:
And the inside:
After fairing and 4 layers of epoxy primer:
moctrams
Re: West System Example 8, page 89
Post by moctrams »
Great job. Now, put some barrier coat on that spot.
hilbert
Post by hilbert »
Oops, I wasn't clear. The 4 coats of epoxy primer (Pettit 4100 white) is a barrier coat.
Although I use West Systems guides, I find their products to be expensive.
For epoxy, I use Clark Craft's Epoxy-Plus marine epoxy at $64/gallon, when purchased in three gallons quantities.
Over the past several years, I have been using between 3 and 5 gallons a year, so the price really makes a difference.
It also has an easy to use 1 to 1 mix ratio and no amine blush.
moctrams
Post by moctrams »
Why all the holes being filled in?
Nice job! Very professional.
hilbert
Post by hilbert »
I prefer this:
Over this:
Squid
Post by Squid »
Most excellent job ! I like the improvement and the install looks PRO.
Glen
S/V SeaEsta
CD 30 MK II, #31
CDSOA Member #1487
Sea Hunt Video
Post by Sea Hunt Video »
Hilbert:
Should there be two (2) hose clamps on each side of the engine's raw water filter or is there not enough bronze pipe to accommodate two hose clamps :?:
hilbert
Post by hilbert »
On the outlet side, the bronze fitting has insufficient length to accommodate two clamps.
