Solar Panel Mount Dry Fit
barfwinkle
Post by barfwinkle »
GA to all
Well here is a pic of how I'm mounting the panels. May need some bracing though!
Bill Member #250.
hilbert
Re: Solar Panel Mount Dry Fit
Post by hilbert »
The vertical tubing does look a bit overwhelmed by it's assigned task.
Do you have a picture of the panels from the back side? How many watts?
Also, is that your primary VHF antenna on the railing, a backup or does it serve some other purpose?
Bill,
I'd feel better if their was some type of cross bracing, something athwartship to keep that assembly from wracking. A 45 degree brace or even a small knee brac would help.
Sorry about our Cards, but they did come close.
