I'm about to put Dolcetto away for the winter in my garage, and I want to rig some slings from the rafters for her mast. The specifications give a Typhoon Weekender's mast a height of 27'. Is that the length of the mast dismounted, measured from the waterline, or measured from the keel?
TIA!
pj
Typhoon Weekender Mast Height
Peter Just
Typhoon Weekender #602, Dolcetto, Spruce Head, ME
"It is not with impunity that we go out on the water, but with sufferance." - Roger C. Taylor
Re: Typhoon Weekender Mast Height
just measured mine its about 24 ft
Ernie
Ernie
Thanks! The 27' must be height above waterline.
Peter Just
How and where is the mast base stepped?
A keel stepped mast will be longer than a mast mounted on the cuddy roof with a hinge plate or a tabernacle.
Maybe look up Dwyer Masts. They have charts on original mast replacement data.
"If I rest, I rust"
Voting Member #490
Voting Member #490
