I currently have a fire extinguisher installed in the forward berth/head area of my Cape Dory 25D. I would like to install a second fire extinguisher in the cockpit area.
My reasoning for this is that, in my mind, there are three (3) likely places where a fire could start - engine room (diesel), stove (alcohol) or battery compartment (2 AGMs in portside cockpit locker).
If I am in the cabin and a fire starts in any of the above 3 locations I can grab the fire extinguisher in the forward berth/head. However, if I am on deck and a fire starts in the engine room or stove it may be sufficiently large that I cannot get down into the cabin to reach the forward berth/head fire extinguisher. That is why I would like to install a second fire extinguisher in the cockpit area. I can reach it from outside the cabin and spray down into the cabin (engine or stove).
I have been trying to locate a place where I can safely install a second fire extinguisher. It is a Badger Dry Chemical Model No. 5MB-6H (5 lb chemical retardant). It weights 11 lbs.
I have thought of installing it on a bracket on the underside of the portside cockpit seat hatch. I would epoxy a piece of wood to the underside of the hatch, install the fire extinguisher bracket to the wood and the fire extinguisher into the bracket. I ALWAYS have the cockpit lockers unlocked when I am aboard (I unlock the cabin hatch and both cockpit lockers first thing on boarding).
Installing on the underside of the portside cockpit seat hatch would make it readily accessible should I be in the cockpit and a fire starts in the engine compartment or stove. My only concern is the fire extinguisher's proximity to the batteries (2 AGMs).
Thoughts
Thanks in advance for any and all suggestions, etc.
