typhoon compression post
I used a 12" piece of all-thread (3/4") but should have used a 24" section to avoid "canting". There are 2 sections of stainless 1" tubing to act as the post. The nuts are threaded in place with a large washer - these can be adjusted to elevate the post to prevent cabin and deck sagging. This has worked fine for the past 5 or 6 years and is completely removable in case I want to do an overnight. Total cost was approx. $50 - $60 and no holes were cut in cabin floor liner or in board that is used to hide the porta potty whenever I decide to take it along. The concept was adapted from a previous post on this board.
- compression post in socket placed on carved 2 x 10 with stanchion socket screwed in place
- DSC07962.JPG (555.75 KiB) Viewed 475 times
- block set over tabernacle bolt heads with stanchion socket screwed in place
- DSC07961.JPG (462.96 KiB) Viewed 475 times
