Typhoon & Trailer for Sale (Sold)
I am winding up the deal on a larger CD and need to sell Grace to make room in the yard. She is a 1974 Typhoon in above average condition according to survey completed in spring 2013. She is set up for single handing with everything led to cockpit. Details:
Rig - Roller furling genoa (130% I believe), Spinnaker rigged including spinnaker and pole, Main with two reef points and jiffy reefing, 4:1 boom vang, 2:1 downhaul, adjustable topping lift, whisker pole, wind indicator, main sail cover.
Interior/cockpit - Full set of cabin and cockpit cushions in like new condition, Tiller tamer, Tiller cover, Solar powered cabin vent.
Electrical/electronics - AGM battery with AC charger, Electrical system completely rewired with new panel (all lights and electronics work), Raymarine depth indicator & electronic compass, Lowrance Elite 4 GPS, handheld VHF radio with charger
Power - 6 HP Nissan Outboard w/ extra long shaft and 12 v rectifier (2005), 3 gal portable tank, traditional Spartan motor mount
Hull - Original gel coat in very good condition, Painted red boot stripe, Bottom paint stripped in 2013, barrier coat, multi-season bottom paint new this year (red ), Stainless steel compression post, New scupper hoses and through hulls, Most deck fittings re-bedded by PO with bronze backing plates. Custom winter cover.
Trailer - Brand new 2013 Load Rite bunk trailer with extra long tongue, LED lights, fenders. Will be used for the first time to haul out this year.[/list]
One soft spot on rear deck at motor mount which will be re-cored prior to delivery. She is already scheduled to go into shop in mid-December with one of the best custom/classic boat fiberglass shops in South Jersey.
The only thing the new owner needs to do is to decide if they want to renew the Cetol on cockpit/cabin top bright work or strip and varnish it. I have the materials for both. Rub/toe rail varnished in 2013 (six coats).
Asking $8,200 with sale contingent upon deal with other boat going through (expected December 10th). Additional photos and survey are available upon request. All photos were taken this morning (11/24/13). Boat is near Atlantic City, NJ.
direct email - swhfire21@hotail.com
- IMG_5212.JPG (2.56 MiB) Viewed 1007 times
- IMG_5211.JPG (5.2 MiB) Viewed 1007 times
- IMG_5197.JPG (4.65 MiB) Viewed 1007 times
Steve
Pleasant Journey, Morgan 35
Previously:
'85 CD 26, Hull No. 30
'74 Typhoon Hull No. 789
Previously:
Re: Typhoon with Trailer for Sale - Near Atlantic City, NJ
Very pretty boat but I live in northern NJ and need to have my Typhoon "S-Cape" bottom striped and a barrier coat applied. What is the name of yard that did your work?
Andy
Andy
I have had all my work done by Pat Francis at PF Custom Marine. He is really into classic boats and very good with fiberglass and wood. I have some postings under projects showing more of his work.
Tell him the owner of Grace referred you. His info. is as follows:
Patrick Francis
PF Custom Marine
4 Spar Drive
Waretown, NJ 08758
pfcustommarine@yahoo.com
(609) 618-6572
Patrick Francis
PF Custom Marine
4 Spar Drive
Waretown, NJ 08758
(609) 618-6572
Steve
Previously:
Previously:
Re: Typhoon & Trailer for Sale (New Price 11/28)
Steve,
Thanks, I will check it out.
Andy
Andy
Steve,
Your Typhoon looks very nice. What do you use as a finish for your woodwork? Varnish? I'm refinishing all of mine this winter and would be thrilled if it came out as nice as yours.
Thanks.
Chris
Thanks.
Chris
Chris,
The rub/toe rails were done with 6 coats of Petit Z-Spar Flagship after stripping (cetol), a very light sanding and wipe down with a Petit recommended thinner to assure adhesion.
The remainder of the wood, as indicated above, was done by previous owner with Cetol Clear, which I had intended to take off and replace with the varnish before the deal on the new boat came about.
Steve
Previously:
Previously:
I've had a couple of inquiries as to whether I would separate the boat from the trailer. I will sell the boat without the trailer at this time. The trailer is not up for sale independent of the boat at this time.
Also, delivery within a hours is negotiable.
Steve
Previously:
Previously:
Grace is sold pending receipt of the deposit.
Steve
Previously:
Previously:
