Forestay/roller furler problems...
D. Stump, Hanalei
Post by D. Stump, Hanalei »
When the yard unstepped the top hamper on Hanalei a few weeks ago, they noticed that the forestay tension was excessive. It appears that the upper bearing on the furler had seized, causing the stay to tighten up/unscrew. Has anyone else had this problem? We didn't notice ANY problem using the furler this past season. She reefed fine every time we used it, never noticed any extra effort to furl the yankee at any point of sail. Second question is: What to do about it? It is a Harken fuller. Any comments would be appreciated....
Dave Stump
Captain Commanding
s/v Hanalei CD-30
Duncan Maio
Re: Forestay/roller furler problems...
Post by Duncan Maio »
Dave:
Try calling Harken directly. I had trouble disassembling the foils on my Model 0 furler last year, and their tech support was fast, helpful and free (even though the unit is ten years old). They don't sell parts direct, but will give you the part number and West Marine can order direct for you.
Good luck.
Duncan Maio
s/v Remedy
CD27 #37
p.s. the way to disassemble parts joined with red Loctite is to apply heat (with a torch). It works like a charm, but keep the flame away from the wire shrouds/stays.
dmaio@meganet.net
Larry Austin
Post by Larry Austin »
Dave, when the yard removed my mast this year (first time since owning the boat) the front roller furling "unsprung" as if it was under spring tension. We discovered that the lower toggle assembly adjustment nut was frozen/rusted to the toggle and could never be
adjusted correctly...anyway I emailed harken and they email back and
said to get the "series number" off the top drum (might be hard to see
because it is covered with paint/coating stuff and give them a call. They said they normally don't sell to the public but will sell repair parts. it was 30 bucks less than west...
Hope this helps...
Larry Austin
CD 30 MKII
LAYLA
laustin@us.ibm.com
Larry Austin
ps..that "series number" is not on the outside chrome(SP) cover, it's on the top of the drum near the welded shaft area thats inside the chrome cover...
laustin@us.ibm.com
Larry Austin
me again! I just found the email from harken and the contact at harken was Jim Bourne at 262 691-7508 x 326. (I think the area code has changed up there...if 262 doesn't work...call the operator!
bye...good luck!!
laustin@us.ibm.com
