Backing plate replacement
I have a 1978 CD27 and looking for replacement backing plates for port and starboard shrouds. Mine have rusted significantly and are in need of replacement. Any suggestions on sourcing these backing plates and how to replace them?
Re: Backing plate replacement
Any fabricator can make them. CD in later years switched to using aluminium rather then mild steel, in your shoes I would consider doing that as well when you replace.
Russell
- tartansailor
Doug,
I replaced mine with 3/16" SS.
The original mild steel ones came out in pieces due to serious rust.
Made a plywood model after much cutting and fitting, then found the holes by marking with an awl.
Had a machine shop reproduce the model in SS.
There was a lot of fiberglass to remove to gain access.
Hint: get a flexible wand to recover dropped tools.
Viam Inveniam Aut Faciam
Dick:
Did you remove the mast for the replacement project?
Doug
Doug
- tartansailor
Oh yes!dougw wrote:Dick:
Doug
another alternative is to use aluminum bronze available in 1/4 plate from onlinemetals
Mark Abramski
