Backing plate replacement
dougw
Post by dougw »
:?: I have a 1978 CD27 and looking for replacement backing plates for port and starboard shrouds. Mine have rusted significantly and are in need of replacement. Any suggestions on sourcing these backing plates and how to replace them?
Re: Backing plate replacement
Post by Russell »
Any fabricator can make them. CD in later years switched to using aluminium rather then mild steel, in your shoes I would consider doing that as well when you replace.
tartansailor
Post by tartansailor »
Doug,
I replaced mine with 3/16" SS.
The original mild steel ones came out in pieces due to serious rust.
Made a plywood model after much cutting and fitting, then found the holes by marking with an awl.
Had a machine shop reproduce the model in SS.
There was a lot of fiberglass to remove to gain access.
Hint: get a flexible wand to recover dropped tools.
Viam Inveniam Aut Faciam
dougw
Post by dougw »
Dick:
Did you remove the mast for the replacement project?
Doug
tartansailor
dougw wrote:Dick:
Doug
Oh yes!
marka
CD 27
Hull 219
Oswego, NY
Post by marka »
another alternative is to use aluminum bronze available in 1/4 plate from onlinemetals
Mark Abramski
