fresh water cooling
fresh water cooling
The exhaust manifold of the 1978 MD7A Volvo engine in my Cape Dory 28 was replaced in 2002 after about 750 hours. In 2010 a clogged coolant pipe was replaced and the engine is running well. Would installation of a fresh water cooling system be practical or possible at this point?
- tartansailor
Re: fresh water cooling
I don't think so.jwkennedy wrote:The exhaust manifold of the 1978 MD7A Volvo engine in my Cape Dory 28 was replaced in 2002 after about 750 hours. In 2010 a clogged coolant pipe was replaced and the engine is running well. Would installation of a fresh water cooling system be practical or possible at this point?
You will still be running raw water through your exhaust.
md7a
Engine still running well.....just bump starter and it goes.....about every ten years have to do a clean out when temp gauge starts to cycle......I try and leave engine with fresh water in the system if not going to run it regular.....add antifreeze if temps cold.....otherwise just leave it as it is when shut down.....lets see 78 88 98 2008 2011 33 yrs and still going ......
Jim Lewis
