I installed Aqua Signal #33 LED Nav lights, trying to keep them as subtle as possible. The sidelights stay protected and yet visible from the front mounted on the cabin side.
The stern light still needs a mounting block to level it, but I thought I would go ahead and install it temporarily as it will take some work to fabricate.
On the interior since the sidelight wiring had to be surface mounted, I faced them off with a plastic wiremold.
I also had a boom tent made out of "Shur Last a Glenn Raven Mills material that is waterproof, breathable,lighter and more packable than Sunbrella. I often camp out in her and will be doing a two week trip to the Canadian Gulf Islands this fall.
