Traveler on typhoon?
nscotia
Post by nscotia »
Anyone install a traveler on a weekender typhoon? And how?
Markst95
Post by Markst95 »
Ned Crockett has a pic on his site with a traveller. You can find more info using the search on this site .
http://stealthink.com/LADYBUG/
gk
Location: Typhoon "Prairie Orchid", Evergreen, Colorado
Traveler
Post by gk »
My Ty (sounds like an adult beverage!) also has a traveler located in the same place as the photos. However, it's about a 1970 vintage, looks very cool, but is not user-friendly. You have to unbolt the car, move the car, then bolt it back down. It's for appearance only.
georgia
Kevin Kaldenbach
Location: Cape Dory 31 “Kerry Ann“. Currently in Corpus Christi TX and Typhoon Weekender “Wimpyâ€
reply
Post by Kevin Kaldenbach »
I installed a Harken traveler on my TY. It is between the comings aft of the cockpit. I cut the track to fit. Marked the holes then drilled them oversized thru the first layer of the deck. Filled the holes with Epoxy then drilled the proper size holes thru the epoxy. I also put a large round access hatch in the transom and used it to get to the nuts.
As far as performance, I love the traveler.
Kevin
CD 31 "Kerry Ann"
kaldenbach.us
nscotia
Traveler on typhoon
Post by nscotia »
Thanks for you input everyone
