We are looking at installing a Dickerson Newport wood burning stove on our Cape Dory 26.
Has anyone installed one?
Any and all comments, advice and suggestions will be greatlly appreciated.
Dickerson Newport solid fuel stove installation
My brother and I did in 2002. On our 33 we placed it on the bulkhead next to the mast. We used an ABI deck fitting and stack/charlie noble, heavy bronze. It works well though it will not hold a fire overnight. You will need small sections of wood about the size of your fist. I dedicated a locker under the starbd berth for the wood bin.
Installation seemed pretty straightforward, my brother put in the stove and I installed the deck ring. He used a piece of 1/2" concreteboard covered with a sheet of copper for the backing on the bulkhead then bolted the stove right through. I installed a teak deck ring he made along with the bronze fitting which was tough to fit the camber of the coachroof. I got it wrong at first and the stack leaned a bit forward for the first two seasons, then I got sick of it and belt sanded the top down to fit the heavy deck ring better and thus the stack.
Every few years I need to pull it off and re seal the deck ring but next time I may use a fireplace sealant as I think the heat shrinks the sealant and then we get leaks in heavy rain. It has been fine for the last few seasons. Every few years I polish the copper as well with neverdull or similar.
If like us you are in a northern climate, I recommend it. A few weeks ago I spent a wonderful night afloat on a chilly night with the stove burning some of my old oak tree trimmings from the year before, found some scotch a friend left aboard, a good book, a little Telemann - perfect. Below is a shot of most of the installation.
The copper looks great! If I ever get around to installing my kerosene heater, I think that would look much nicer than the usual steel.Paul D. wrote:... a sheet of copper...
With reference to burning overnight, L. Francis Herreshoff left instructions on how set up a coal stove to burn overnight (The Compleat Cruiser, p. 21, available on Google Books).
I don't know if anything there would be helpful for you, but I always like reading what he says anyway.
- RIKanaka
- Location: 1988 CD26 #73 "Moku Ahi" (Fireboat), Dutch Harbor, RI
Same boat, different heater
Here's a picture of a Force 10 propane Cozy Cabin Heater installed in my CD26 by a prior owner, using ceramic tile on backer board (I believe), the upper 6 inches of which are obscured by the folded table in the picture.
I have not used this heater and don't know if this is a proper installation or if it is applicable to your proposed installation.
Aloha,
Bob Chinn
Bob Chinn
Re: Same boat, different heater
It's nice and low, which is good for heat, right?RIKanaka wrote:I... don't know if this is a proper installation
I think the bulkhead-mounted table is an issue, though. The heater and table don't look well-integrated to me, and it generally looks like the table and the heater are in each other's way. I've never seen a heater installed this way.
I don't see any scorch marks on the underside of the table, but that's what I would be worried about: I don't think I'd want to try operating the heater with the table down. On the other hand, the top of the table may be vulnerable to heat from the chimney when the table is up. Is the bulkhead behind the table protected by a heat shield, or is it bare?
In short, it looks like the table could move from the bulkhead. It could be mounted on removeable legs, like on the CD 27.
