spartan seacock & thru-hull fittings for CD25D
Moderator: bobdugan
Hi:
First timer in this Forum. Just got my first S/V, a 1983 CD25D Hull #109 named Juno. Bought it in Tortola BVI and sailed it to Puerto Rico this last August.
I need advice regarding the dimensions (specifications) of the spartan seacocks & thru-hull fittings for Juno, particularly for the intake water, the scuppers and sink. Thanks
- barfwinkle
as memory serves me the scuppers are 1 1/2" and the intake/galley drain are 1/2".
Congrats on the acquistion.
fair winds and as always
We hope to see you in Havre de Grace
Bill Member #250.
Re: spartan seacock & thru-hull fittings for CD25D
Was this the one that was sitting on the hard in sopers hole for several years? If so I am glad it was sold and bought, as I never saw it splashed or get used.cjrs472 wrote:Hi:
Did you stop in Culebra on your way to PR? There is a 25D in Culebra that a fellow named Laurence lives aboard (forgot his boats name). Certainly someone you could swap tips on the boat with (he has sailed it far and wide).
Russell
seacock
I have been on the board for about 10 yrs. I would call Spartan ,they are very helfull and knowledgble....it will save you a lot of time..by the way dont dont dont]expect the waste hose to just jump back on the valve fitting ..some yards use a tool to heat the hose up and expand it so that it fits..seems a 3/4 fitting is actually 7/8 or so ..I had a *&^&^^* of a time getting my new hose back the head seacock..
none
- barfwinkle
Same issue
I too had a very tough time the the sanitary hose. You would not believe what all we did!I had a *&^&^^* of a time getting my new hose back the head seacock.
Anyway, when i replaced the scupper hose, I had the same issue, so I just went to 1 5/8" hose. Don't know if that would work on the head hose, but it did on the scuppers and it would it would be well worth the $$$$$$$$$$ if you can do the same on head hose!
Bill Member #250.
