Outboard power
Outboard power
My original 8.8 Nissan is now cranky and too heavy to heft in and out of the well on my CD25. What do you think of Tohatso 6hp long shaft? Will it push okay...is the non-electric start feature a stopper?
Are there any other options? Thanks!!
Sea Cliff, NY
Member #1209
I've got the extra-long shaft Sail-Pro and leave it in the drink (with a coat of Trilux).
It pushes fine under my conditions, but at least for me would be a pain to haul and stow every trip. The long shaft would be easier to stow but you'll have to add the charger if you want it. The pull-start has been fine. I built a new motor mount (notched and longer) so that the lazz cover would shut.
Do a forum search under Tohatsu for many other opinions.
- Location: Cape Dory 25 s/v little Ebby Rose Haven, MD. (sadly sold)
Tohatsu 6 Sail Pro
Another vote for the Tohatsu 6 Sail Pro! I just put a new one on my boat and it works great. Pushed Glimmer along at hull speed with 3+ foot seas and a 20+ mph head wind...at only 1/2 to 3/4 throttle. I used to have the shorter shaft, which worked fine, but would come out of the water sometimes in large swells or when contending with swells from big old stink boats that would come by going to a fire or somewhere obviously very important.
Kilgore...I'd be interested in your motor mount. Mine has been knotched but the bottom of the mount does hang over...and the motor cover still hits the lazz cover. If you have them readily available, what are the dimensions on it?
CDSOA Member Number 1252
- tartansailor
Engine Mount
I had an 8 hp Honda that would positively not fit for height.
My solution was to put 2" blocks between the aft deck and the hinges supporting the engine hatch.
This insured plenty of air for the motor and avoided the notch regimen.
Sold the Honda and am now saving up for the long shaft sail pro.
- Sea Hunt
Tio Pepe:
As suggested by Kilgore, if you do a search on this board you will find several threads on recommended and not recommended O/Bs for a CD 25. This may be one:
http://www.capedory.org/board/viewtopic ... 5+outboard
I am sure there are others.
Good luck
Good luck
Robert
Robert
me too
I would be interested in this modified motor mount
Greg Lutzow
Nokomis, FL
CD25
"Beau Soleil"
Nokomis, FL
CD25
"Beau Soleil"
Mount
Cool...the notch sounds close to what mine is. Do you run your motor with the cover closed? It sure would be quieter. Although, my motor tiller is not run through the opening. I fold it up to close the cover. I usually turn the motor alot when pulling into and out of the slip.
Sea Cliff, NY
Member #1209
http://rapidshare.com/files/406443880/s ... 10_112.JPG
I run it with the cover closed. The motor tiller doesn't fit through the opening.
6HP Nissan/Tohatsu
I have the 6HP Nissan/Tohatsu in SPRITE. Works very well. No problem in up to 20kt wind, but in 4kt current you don't make much speed over land due to hull speed.
I have an inspection plate in the lazarette cover to allow access to the throttle with the cover closed -- it is very useful. I do need to open it up to shift though, and the windage of the open hatch makes a noticeable difference, usually in early spring when it's windy and I'm rusty.
Jeff
Jeff
