Replacing a stove in my 30ft cutter
Richard G. Abbinanti
Name of Boat -Blue Caribbean- hull # 208
Long Island NY
Post by Richard G. Abbinanti »
Could use some help
Was looking on replacing my stove , I have been looking at the following.
1. Seaward princess Euro 2 burner
2. Tasco 2 burner
Both would be propane.
Anyone?
Richard
Cathy Monaghan
Post by Cathy Monaghan »
Hi Richard,
We've got a gimballed Tasco (Taunton Stove Co.) 2-burner propane stove/oven combo (# 550LP-SS) on our CD32. It does the job.
Cathy
CD32 Realization, #3
Rahway, NJ
Raritan Bay
moctrams
Origo
Post by moctrams »
I replaced "Gabbi's" old stove with the Origo Non-Pressurized, 2 Burner Stove With Oven. I even bake bread in it. I did not have room for the propane tank and the Origo "fit like a glove".
Long Island NY
Where did you place the propane tank
Cathy
Can you tell me where you placed the propane tank( inside or out).
And did you install a fan ?
Defender has it on sale this weekend for $809.99.
Richard
Neil Gordon
Re: Origo
Post by Neil Gordon »
moctrams wrote:I replaced "Gabbi's" old stove with the Origo Non-Pressurized, 2 Burner Stove With Oven. I even bake bread in it. I did not have room for the propane tank and the Origo "fit like a glove".
I've been happy with the Origo 2 Burner (without the oven). It's supplemented by the Forespar Mini-galley.
Cathy Monaghan
Re: Where did you place the propane tank
Richard G. Abbinanti wrote:Cathy
Richard
Hi Richard,
Our CD32 came factory-equipped with a propane stove and propane locker. The propane locker is located on the starboard side, aft, in the cockpit. The locker is sealed off from the rest of the boat and is vented overboard. We have fans, but no bilge fan. The hose is protected -- it's inside another hose. And we do the old soap test on the fittings each spring.
- Cathy
Rahway, NJ
Raritan Bay
mgphl52
convert CNG to propane
Post by mgphl52 »
Is it possible to convert a CNG stove/oven to use propane?
If so, how difficult & costly is the conversion?
-michael
Cathy Monaghan
Re: convert CNG to propane
mgphl52 wrote:Is it possible to convert a CNG stove/oven to use propane?
-michael
You have to replace the burners and air orifices on the stove as well as the pressure regulator. So you'll have to contact the stove manufacture and ask if they have a conversion kit.
I found this on wiki.answers.com. Maybe it'll help a little:
http://wiki.answers.com/Q/How_do_you_co ... atural_gas
Cathy
Rahway, NJ
Raritan Bay
Joe Mac Phee
convert cng to propane
Post by Joe Mac Phee »
Michael,
You probably only need to replace the orifice(s).
If you have a Force 10 stove, it should be easy. They provide the same stove as CNG or LPG. They will have a kit to convert and it should be inexpensive. For other vendors, the experience seems to be more problematic. Contact the manufacturer.
Joe Mac Phee
Jeff Barnes
Stove conversion
Post by Jeff Barnes »
I believe Joe is correct in that only the orifices need to be changed to smaller ones for LP. The regulator will also have to be changed. LP pressure runs at about 11" of water column, whereas natural gas runs 5-6". I believe your burners can remain the same.
Good luck
Jeff
CNG to Propane Conversion
I have CNG Seward Princess three burner with oven that came with my boat. I bought the conversion kit for propane. I'll have to see what I have, the stuff is still in the box. I think I have new burners, which I needed because the old ones were shot, new orifices, and a new thermocoupler. I think I needed the orvices and thermocoupler to change over--but honestly I don't remember. I worked with the folks at Seward and they were helpful. The stove should be going into the boat sometime next fall and I'll make the conversion then.
Best of Luck.
REGULATOR TOO
I forgot to mention in my post that I also have a new regulator for propane too.
mgphl52
Post by mgphl52 »
Thanks for the info! It's not n urgent item on our list (yet...) just curious about the possibilities, cost, etc. The stove & oven are apparently original (circa 1972) but look totally unused. The manufacturer was Gas Systems Inc. When we get to that point, I may be lucky and find that generic orifices work... and maybe not, but such is life.
Thanks again,
-michael
