Cape Dory 25
Cape Dory 25
Well, I finally found a boat that I am going to purchase. It is a Cape Dory 25. My question is will my vehicle pull it? My truck is a Toyota Tundra V8. The stated gross weight recommended to tow is 5000lbs. However, I cant find the gross weight of the cape dory mentioned anywhere. I see mention of 4000lbs of displacement but don't know if you can convert this. Any help would be appreciated. Thanks.
- Cathy Monaghan
- barfwinkle
wouldnt the 4000 lbs be the "Empty" gross weight. Then you'll need to add the weight of the trailer and any stores/sails/fuel etc.
Or at least that's my take.
Congratulations of your new to you little yacht.
Fair Winds
Oh and FWIW, in the past I towed my 25d (as much as 6oo miles & 5150 dry weight) with an F-150 ford. It did the job just fine.
See yawl in Havre de Grace
Fair Winds
Bill Member #250.
We have an absolute weight limit on our hoist at the Sailing Squadron here in Sarasota so I was required to weight my CD25 before using the hoist. The ship with rigging, motor and gear came in at 4875lbs. Keep in mind that this is a 1979 ship with a 5hp Honda outboard and that weight does not include the trailer.
I hope this helps.
I hope this helps.
Greg Lutzow
Nokomis, FL
CD25
"Beau Soleil"
Nokomis, FL
CD25
"Beau Soleil"
Shavdog is right.
The Tundra won't even feel this boat. But your hitch might, if it's not of the correct class. If you just have a ball on your bumper step, you will need to upgrade the hitch. 5,000 pounds is a Class III hitch. A Class IV hitch will go up to 12,000 pounds. Check out this link for more information.
http://hitches4less.com/trailer-hitch-classes.html
Sir Isaac Newton
Sir Isaac Newton
- barfwinkle
Important Note Shavdog
I was within 100 miles of home last summer returning from the Chesapeake (2500ish miles round trip), had stopped for fuel, and heard a hissing?????
What the Crap? I looked and the tread was separeting on one of my trailer tires. Sure glad it happened where it did. Wouldn't even like to have that happen driving 60 mph (which is what I drive with the boat).
And every time I travel any distance, the trailer wheels get repacked. Here it is only $25 a tire. Cheap insurance. Also Trailer Assist for Boat US very affordable in the grand scheme of things. My AAA will only cover the tow vehicle so I would have to leave the boat and trailer behind if something happened to the truck.
Thanks for reminding me shavdog. Oh and make sure your spare tire has the same rating as the tires on the ground!!!!! Dont ask
Oh and everytime you stop (at the very least for fuel) check your trailer!!!!!
Fair winds and I hope to see you in Havre de Grace
Bill Member #250.
trailering a 25
I've towed my 25 up over the Continental Divide [Berthaud Pass Colorado] several times with a F-150...no sweat...a little slow going up but plenty fast coming down. [Trailer brakes are good insurance.]
S. Calder sv Falcon
displacement vs. mass (weight)
Displacement is the mass of the water that the boat displaces when placed in water. The mass of the boat is the actual weight of the boat. The difference between the mass of the boat and the displacement of the boat gives it its bouyancy and allows you to put sails, gear, people and provisions on board. If the mass and displacement were the same, you would not be able to add any of these to the boat. Displacement can also change depending on the shape of the boat.
To concur with others, your Tundra should be fine towing the CD25. The weak link in towing is the hitch, tongue and ball. Make sure those have a 10,000 lb or 12,000 lb rating.
Illegitimus non carborundum
I made it!!
Well I made the Trip. No big problems. I made about 10 mpg (there goes the college fund for the kids) It took around 22 Hrs. The only problem that I had was that the boat was slipping forward and I couldnt figure out why until I got about an hour from my house. The boat is on a cradle that is bolted to a trialer. I didn't feel comfortable with the fiberglass to steel connection so I jacked the boat up and placed plywood to cushion the blows. Once the plywood worked itself out the boat stayed still. You live and you learn. Thanks for all of the replies.
Re: displacement vs. mass (weight)
Correct in both cases, sinceviv wrote:Displacement is the mass of the water that the boat displaces when placed in water. The mass of the boat is the actual weight of the boat.
1) Archimedes' principle states that a floating boat will displace its weight in water, and since
2) mass=weight (on the Earth's surface).
So, for a floating boat, mass=weight=displacement
None of this is true. The reason boats float is that they are less dense than water. The reason you can load up a boat and still have it float is still because of this difference in density. The shape of the boat has nothing to do with this.viv wrote:The difference between the mass of the boat and the displacement of the boat gives it its bouyancy and allows you to put sails, gear, people and provisions on board. If the mass and displacement were the same, you would not be able to add any of these to the boat. Displacement can also change depending on the shape of the boat.
The buoyant force acting on the boat is equal to its displacement. This is just a fancy way of saying that it floats - the weight of the boat is exactly counteracted by the greater density of the water.
Hmmm...Duncan wrote:Correct in both cases, sinceviv wrote:Displacement is the mass of the water that the boat displaces when placed in water. The mass of the boat is the actual weight of the boat.
So, for a floating boat, mass=weight=displacementNone of this is true. The reason boats float is that they are less dense than water. The reason you can load up a boat and still have it float is still because of this difference in density. The shape of the boat has nothing to do with this.viv wrote:The difference between the mass of the boat and the displacement of the boat gives it its bouyancy and allows you to put sails, gear, people and provisions on board. If the mass and displacement were the same, you would not be able to add any of these to the boat. Displacement can also change depending on the shape of the boat.
Question 1: How does a boat go from a 14,500 lbs "stated displacement" to a "travel lift weight" of 22,000 lbs?
Question 2: Why are objects easier to lift will they are submerged?
