Lost my rudder Typhoon weekender 1971 - HELP
Carlos Crucet
Post by Carlos Crucet »
Is there anyone who might have the specs on a 1971 typhoon rudder. I need to make a new one, and the builder needs specs. Any input would be greatly appreciated. I went to the web site and was able to find a diagram, but I also need measurements.
1971 Typhoon Weekender Hull # 137
Key Largo, FL.
Oswego John
Typhoon Rudder
Post by Oswego John »
Hi Carlos,
If you want to, PM me your USPS address and I will send you a template and specs for a new rudder.
"If I rest, I rust"
Voting Member #490
Oswego John
Typhoon Rudder
Hi Carlos (again),
After rereading your post, I see that you have access to the diagram. Here are the specs.
A: Height along the rudder post (foreward edge), 27 1/2"
B: Height of spur at top of rudder blade, 3"
C: Width of rudder blade, 13 1/4"
D: Thickness of rudder blade, 3/4"
"If I rest, I rust"
Voting Member #490
windwalker111
Cape Dory typhoon
typhoon rudder
Post by windwalker111 »
The rudder of a typhoon that I am rebuilding has been damaged from improper loading on the trailer by a travel lift. It has broken away from its suport. I am not even sure how to remove the old blade. It feels like a metal part at the base of course, it is under several coats of bottom paint so I can't be sure. Does it some how come loose and drop after a base plate is removed? Then once off does the whole thing need to be reglassed or can it be replaced? I assume there is a bronz or stanless shaft with the rudder sandwiched around it. It sounds like you have worked on your rudder before can you ive me some advice? Thanks
Windwalker111
Happiness is the best revenge
