Cutlass bearing size -- CD 27?
Steve Behnke
"Altariel", Juneau, Alaska
Post by Steve Behnke »
Does anyone know the interior and exterior diameters of the stern tube, and proper length and diameter for the cutlass bearing for the CD 27 (1980)?
Boat is in the water, and I'd like to have the part ordered and on hand before hauling it and doing some work this spring.
Thanks.
trapper
CD25D, Lake Murray SC
Cutlass bearing
Post by trapper »
Hi Steve,
We just replaced Saga's (25D). I think the size for yours should be listed in the owner's manual. I think it may be "blackfish". Good luck!
Jimbo
Location: cd 27 malletts bay vt. Cattail cd 14 #65 cd 10 #2251
Post by Jimbo »
Cutlass Bearings, Johnson Duramax Cutless® Bearings, Naval Brass Sleeve: Standard Size
All Products Specials Contact Us Boating Help Create an account Customer Login
We Ship To Over 60 Countries, Including: Calculate Your Shipping Now
Search Our Products
Search our online catalog by:
Part Number or Description
Online Store
Propellers
Inboard Propellers
Outboard Boat Propellers
Sterndrive Boat Propellers
Volvo Duo-Propellers
Ski/Wake Boat Propellers
Propeller Pullers
Propeller Cases
Nylon Bore Reducers
Propeller Help
Propeller Guide
Inboard Propeller Sizing
Product Inquiry
Zincs
Zinc Anodes
Shaft Hardware
Stainless Boat Shafts
Cutlass Bearings
Shaft Seals
Engine Coupling Guide
Engine Couplings
Shaft Logs
Packing Boxes
Marine Hardware
Underwater Hardware
Deck Hardware
Exhaust Fittings
Steering Parts
Hose and Clamps
Electronics
GPS Fishfinder/Plotters
GPS Color Plotters
Fishfinders
First Aid/AEDs
Product Catalog
Download Catalog
Contact Us
General Sales Department
(800) 454-6960
(954) 444-6259
sales@deepblueyachtsupply.com
Inboard Propeller Questions
Use our 'Inboard Propeller' Form
Or call us at:
(800) 454-6960
(954) 444-6259
Outboard Propeller Questions
Use our 'Outboard Propeller' Form
Or call us at:
(800) 454-6960
(954) 444-6259
We gladly accept:
Cutlass Bearings - Johnson Duramax Cutless® Bearings - Naval Brass Sleeve: Standard Size
Item description:
These cutlass bearings adapt equally well to strut and sterntube mounts, and are often used efficiently as rudder stock and pintle bushings. Bearing diameters are precision fitted to the designated shaft size with the correct clearance for efficient water lubrication.
External brass shells are machined and polished to provide easy fitting. Specially formulated oil and chemical resistant nitrile rubber is securely bonded to the shell.
Model Number Shaft Diameter (in.) Outside Diameter (in.) Length (in.) Metal Thickness (in.) Weight (lbs.) Price
ABLE 3/4 1 1/4 3 1/8 0.5 $72.50 $33.35
ACID 7/8 1 1/4 3 1/2 1/16 0.4 $78.24 $35.99
APEX 7/8 1 3/8 3 1/2 1/8 0.7 $77.42 $35.61
ATOM 7/8 1 1/2 3 1/2 1/8 0.8 $87.16 $40.09
BACK 1 1 1/4 4 3/64 0.4 $75.81 $34.87
BADE 1 1 1/4 6 1/16 0.9 $108.19 $49.77
BAIT 1 1 3/8 4 1/16 0.5 $80.13 $36.86
BALE 1 1 1/2 4 1/8 0.7 $78.43 $36.08
BAND 1 1 5/8 4 1/8 0.9 $79.84 $36.73
BASE 1 2 4 1/8 1.3 $100.52 $46.24
BEAM 1 1/8 1 1/2 4 1/2 1/16 0.6 $99.32 $45.69
BELT 1 1/8 1 5/8 4 1/2 1/8 1 $96.09 $44.20
BEND 1 1/8 1 3/4 4 1/2 1/8 1.1 $104.44 $48.04
BILL 1 1/8 2 4 1/2 1/8 1.4 $111.37 $51.23
BIND 1 1/4 1 1/2 5 1/16 0.6 $100.52 $46.24
BIRD 1 1/4 1 3/4 5 1/8 1.2 $82.70 $38.04
BITE 1 1/4 2 5 1/8 1.5 $106.15 $48.83
BLOW 1 1/4 2 1/8 5 1/8 1.7 $116.98 $53.81
BOAT 1 3/8 1 7/8 5 1/2 1/8 1.4 $112.87 $51.92
BOLD 1 3/8 2 5 1/2 1/8 1.5 $122.71 $56.45
BOND 1 3/8 2 1/8 5 1/2 1/8 1.8 $128.94 $59.31
BOOT 1 3/8 2 3/8 5 1/2 1/8 1.8 $135.16 $62.17
BOSS 1 1/2 2 6 1/8 1.6 $139.98 $64.39
BRAD 1 1/2 2 3/8 6 1/8 2.2 $147.92 $68.04
BREW 1 5/8 2 1/8 6 1/2 1/8 2 $165.77 $76.25
BRIM 1 5/8 2 5/8 6 1/2 1/8 2.6 $177.24 $81.53
BROW 1 3/4 2 3/8 7 1/8 2.3 $172.47 $79.34
BUCK 1 3/4 2 5/8 7 1/8 2.8 $176.32 $81.11
BULB 1 7/8 2 5/8 7 1/2 1/8 2.8 $187.01 $86.02
BULL 1 7/8 2 15/16 7 1/2 3/32 3.1 $206.34 $94.92
CALL 2 2 5/8 8 1/8 2.8 $196.21 $90.26
CALM 2 3 8 1/8 3.8 $200.97 $92.45
CAME 2 1/8 2 15/16 8 1/2 1/8 3.1 $232.31 $106.86
CAMP 2 2 3/4 8 1/8 3.3 $198.65 $91.38
CAPE 2 1/8 3 1/8 8 1/2 1/8 4.1 $257.13 $118.28
CARD 2 1/4 3 9 1/8 3.9 $216.84 $99.75
CARE 2 1/4 2 15/16 9 3/32 3.1 $244.48 $112.46
CART 2 1/4 3 1/8 9 1/8 4.3 $254.71 $117.17
CASE 2 1/4 3 3/8 9 1/8 5.1 $280.86 $129.20
COOK 2 3/8 3 3/8 9 1/2 1/8 4.8 $305.50 $140.53
CORD 2 1/2 3 1/8 10 1/8 4.5 $300.33 $138.15
CORN 2 1/2 3 3/8 10 1/8 5.1 $302.15 $138.99
COVE 2 1/2 3 1/2 10 5/32 6.6 $321.50 $147.89
CRAB 2 5/8 3 3/8 10 1/2 1/8 5.2 $346.46 $159.37
CROW 2 3/4 3 3/8 11 1/8 4.8 $350.22 $161.10
CUBE 2 3/4 3 1/2 11 5/32 6.6 $359.13 $165.20
CURD 2 3/4 3 3/4 11 1/8 6.6 $368.17 $169.36
CURE 2 7/8 3 3/4 11 1/2 1/8 6.5 $405.17 $186.38
DANE 3 3 3/4 12 1/8 6.8 $393.72 $181.11
DARE 3 4 12 1/8 7.7 $406.08 $186.80
DARK 3 1/8 4 1/4 12 1/2 1/8 8.6 $486.56 $223.82
DARN 3 1/4 4 13 1/8 7.8 $468.65 $215.58
DELL 3 1/4 4 1/4 13 1/8 8.7 $488.72 $224.81
DIKE 3 3/8 4 1/2 13 1/2 1/8 10.2 $532.73 $245.06
DINE 3 1/2 4 1/4 14 1/8 8.9 $525.77 $241.85
DOCK 3 1/2 4 1/2 14 1/8 10.3 $530.17 $243.88
DOLE 3 5/8 4 1/2 14 1/2 1/8 10 $593.34 $272.94
DONE 3 3/4 4 1/2 15 1/8 9.6 $608.28 $279.81
DOVE 3 3/4 5 15 3/16 16.5 $682.10 $313.77
DRAW 3 3/4 5 1/4 15 3/16 18.2 $757.74 $348.56
DULL 3 7/8 5 1/4 15 1/2 3/16 18.7 $807.50 $371.45
EARN 4 5 16 3/16 16.9 $813.03 $373.99
EASE 4 5 1/4 16 3/16 18.7 $873.94 $402.01
ECHO 4 1/8 5 1/4 16 1/2 3/16 19 $1,008.96 $464.12
EDGE 4 1/2 5 3/4 18 3/16 23.7 $1,108.87 $510.08
EDIT 4 1/4 5 1/2 17 3/16 22 $975.27 $448.62
ELSE 4 3/8 5 3/4 17 1/2 3/16 23.7 $1,061.07 $488.09
EPIC 4 1/2 5 1/2 18 3/16 21.3 $1,039.05 $477.96
EVEN 4 5/8 6 1/8 18 1/2 1/4 42 $1,326.19 $610.05
EVER 4 3/4 6 1/8 19 1/4 41 $1,396.75 $642.51
EVIL 4 7/8 6 1/8 19 1/2 1/4 41.7 $1,532.74 $705.06
FACE 5 6 1/8 20 1/4 42.3 $1,488.02 $684.49
FACT 5 6 1/2 20 1/4 50 $1,600.10 $736.05
FADE 5 1/4 6 3/4 21 1/4 50.3 $1,771.37 $814.83
FARE 5 1/4 7 21 1/4 55 $1,829.37 $841.51
FEAR 5 3/8 6 3/4 21 1/2 1/4 51.3 $1,946.27 $895.28
FELT 5 3/8 7 21 1/2 1/4 56 $2,004.68 $922.15
FIND 5 1/2 7 22 1/4 56 $2,078.51 $956.11
FLAT 5 5/8 7 22 1/2 1/4 55.5 $2,136.43 $982.76
FORK 5 3/4 7 23 1/4 56.5 $2,206.99 $1,015.22
FUEL 5 7/8 7 1/2 24 1/4 65.8 $2,282.88 $1,050.12
GALE 6 7 1/2 24 1/4 66 $2,321.87 $1,068.06
Similar Products of Interest
Cutlass Bearings
Naval Brass Sleeve: Metric Size
These cutlass bearings adapt equally well to strut and sterntube mounts, and are often used efficiently as rudder stock and pintle bushings. Bearing diameters are precision fitted to the designated sh...
Cutlass Bearings
Flanged Naval Brass Sleeve
Johnson Cutless Flanged Type Water Lubricated Bearings are centrifugally cast naval brass with an integral flange for bolting to stern tube or strut housing to retain brearing and prevent rotation in ...
Cutlass Bearings
Non Metallic Sleeve: Standard Size
These non-metallic sleeve cutlass bearings feature a dense structure of engineered reinforced thermoset plastic. The specially compounded nitrile rubber is securely bonded to the shell with all tolera...
Cutlass Bearings
Demountable Stave Bearings
Demountable Rubber Stave Bearings * Tough, molded, nitrile rubber bearing staves * Allow bearing change-out without shaft or propeller removal * Choice of bearing sizes available for each bearing...
Cutlass Bearings
Non Metallic Sleeve: Metric Size
I beilieve I use (back) sold by www.deepblueyacgtsupply.com
Copyright © 2009 Deep Blue Yacht Supply, Inc. Privacy Policy Disclaimer Shipping and Return Policy Boater's Blog Partner Links
Jimbo
Post by Jimbo »
Hey I guess it didn't work. look at the list. I installed (Back) on my 27 last spring.
Cathy Monaghan
Morse "Blackfish"
Post by Cathy Monaghan »
The cutlass bearing model for our boats (1" shaft) is the Morse Blackfish. If you GOOGLE "Morse Blackfish" you'll find what you're looking for. Compare prices. There's a wide difference in pricing, for example, West Marine wants over $100 for the Blackfish bearing and Boatman's I-netmarine.com only wants $56.13.
lubeckmaine
Packing
Post by lubeckmaine »
Cathy, incidentally, what is the correct flax packing diameter for our 1" shaft? Jimmy PS Currently, pretty cold in Boot Key Harbor, Marathon
Cathy Monaghan
Re: Packing
lubeckmaine wrote:Cathy, incidentally, what is the correct flax packing diameter for our 1" shaft? .....
According to my owners manual "All CDY stuffing boxes use 1/4" waxed flax packing." And that's what we've used since we've owned the boat. It's a 1" shaft so the diameter is 1". The circumference (the distance around the shaft) equals pi x d. pi is 3.14 so you'll need 3.14" of packing to go around the shaft once. You should be able to get three 3.14" strips of packing inside the stuffing box.
By the way, the stuffing box for the rudder also uses that same 1/4" packing.
Cathy
CD32 Realization, #3
Rahway, NJ
Raritan Bay
PS: By the way, in 2008 we replaced the Spartan stuffing box with a PYI dripless shaft seal.
lubeckmaine
Good info, thank you. I was lucky- was able to easily adjust to the proper drip because wasn't looking forward to repacking in the water ( It's cold in Marathon). Jimmy
