For those who might care, a couple of pointers: (1) The very early hull numbers of the CD36 (mine is #2) have a lazarette configuration different from the main production run (lazarette hatch is larger), and the standard support brackets from Scanmar for the CD36 didn't fit (you know about "assume"). I took the measurements and Scanmar shipped me a new set of brackets at no charge, which fit perfectly. (2) The "sheets" (control lines led to the wheel) are unobtrusive, IMO. I led the starboard line to a turning block at the very aft end of the port coaming, thence forward to a block on the port coaming in the plane of the wheel, thence to the wheel. I led the port line straight to a block on the port coaming in the plane of the wheel, thence to the wheel. This arrangement leaves the lazarette locker unobstructed, and gives access to the aft end of the cockpit around the starboard side. Because my coamings are 1" teak (3/4" actual), I reinforced the coaming in the area of the two blocks by the wheel with a second piece of teak, with the grain running at 90 degrees to that in the coaming.
Now the question: I have cobbled together some shock cord to act as a control line, but it's not a super arrangement. Any suggestions from those who have lived with this kind of system? What do you use for cord? Where did you lead it to? What do you use to prevent slippage? Did you splice it into a loop, and if so how?
Thanks.
Larry
lshick@ibm.net
