As discussed on another post, the prior owner had installed a hose that, while somewhat flexible, was rigid enough to require making a 360 loop in order to properly line up from the scupper fitting to the seacock fitting.
I removed this "rigid hose" and installed a much more flexible hose. However, it is so flexible that it "kinks" in two places and partially restricts water flow from the scupper through the seacock. It was, and is, a temporary solution.
I have found a product called "flexible PVC pipe" (or hose). It appears to be more flexible than the hose that was on my Ty but does not appear to "kink" when bent.
The website is:
http://www.flexpvc.com/PVCPipeSize.shtml
The website has a lot of information, charts, etc. and provides very detailed information about applications, etc.
I plan to order 5'-6' of the following flexible PVC pipe (1" ID) and see if it will be flexible enough to connect the scupper drain with the seacock without "kinking"
http://www.flexpvc.com/cart/agora.cgi?p ... y_The_Foot
My plan is to attach it with two s/s hose clamps at each nipple.
Question: Given the fact this hose will be a critical piece of equipment to keep out the Atlantic Ocean, from its description, etc., does it appear to be a satisfactory application
![Question :?:](./images/smilies/icon_question.gif)
Thanks in advance for any and all assistance, suggestions, thoughts, etc.
