The hex nut on my aft portt stanchion is stripped. I would like to drill it out, but the coaming is too close for me to use my drill. Any suggestions?
<Davis1@cwix.com
stripped hex nut on stanchion
Re: stripped hex nut on stanchion
Beg, borrow, or steal a 90 drill (I think the is the correct term)and see if it will fit!
Bill
cd25d@clnk.com
Bill
Mike Davis wrote: The hex nut on my aft portt stanchion is stripped. I would like to drill it out, but the coaming is too close for me to use my drill. Any suggestions?
cd25d@clnk.com
Why not jam an "easy out" into the stripped hex nut. If you can find the right size, and if it will fit in the tight space you've got, I would think an "easy out" would bite right into the stripped hex nut. Then you'd be able to remove the old one and replace it.
rdtec@aol.com
rdtec@aol.com
Hi,Mike Davis wrote: The hex nut on my aft portt stanchion is stripped. I would like to drill it out, but the coaming is too close for me to use my drill. Any suggestions?
If you have room you may want to try cutting a slot into what's left of the hex head with a hacksaw or just a blade. Then use a flat screwdriver in the slot you made with the saw. An offset screwdriver may get in there if the space is really tight.
John
