Strangely our owners manual is missing the hull spec's on CD 31ft cutter rig #11. Does anyone have these? (ie.beam, draft, waterline, overall etc.) We would greatly appreciate any help, since we are planning a trip to Bermuda and want to calculate load for our trip. Thanks in advance. Michelle
herozyzzx@aol.com
Specifications on CD 31
Re: Specifications on CD 31
Michelle,
Roger Marshall's "Guide to Production Boats" lists the following data for the CD31 cutter:
LOA 31'4"
LWL 23'3"
Beam 9'9"
Displacement[deep keel] 11,500lbs.
Ballast 4350lbs
Sail area 504 sq. ft.
Fresh water 84 gals.
Fuel capacity 20 gals
SA/D 15.83
D/L 408.49
Ballast ratio 37.83
Fuel/Disp 1.30
Fresh water/Disp 5.84
Hope this helps.
LOA 31'4"
LWL 23'3"
Beam 9'9"
Ballast 4350lbs
SA/D 15.83
D/L 408.49
Ballast ratio 37.83
Fuel/Disp 1.30
Hope this helps.
The specs for all of the Cape Dories are located right here at the CCDOA website at <a href="http://www.toolworks.com/capedory/ccdoi ... m#specs</a>.
This is a great website, please feel free to try all of the links, not just the message board.
catherine_monaghan@merck.com
CD32 Realization
Raritan Bay
CD32 Realization
Raritan Bay
michelle cormier wrote: Strangely our owners manual is missing the hull spec's on CD 31ft cutter rig #11. Does anyone have these? (ie.beam, draft, waterline, overall etc.) We would greatly appreciate any help, since we are planning a trip to Bermuda and want to calculate load for our trip. Thanks in advance. Michelle
Michelle,
Isn't the 31 great?! If you are going to Bermuda, the most important spec. is:
Draft = 4'9"
I just went through our Owner's Manual, and you're absolutely right; no specs.
I assume you have the sail plan numbers (I, J, etc.)
If you are going long distance to Bermuda, my wife and I would love to hear all about it. We are in New England, and this type of cruise is a dream of ours (mine anyway!).
Wishing you fair winds and a calm Gulf Stream.
skuhlman@sprynet.com
Draft = 4'9"
