Galley pump priming?
The water tanks on my CD33 ran dry. So I filled them. But when I turned on the pump and the galley faucet, the water just spit out a little bit. I could see the pump running but it did not seem to be pulling the water up. Do I need to prime the pump? Or, might it be that the pump is bad? I switched to all 3 different tanks with the same result.
