I have an issue of concern to me - one of many. The owner, a very nice gentleman, advised me that when you go forward to the bow to hank on the jib/genoa, you must first turn off the O/B motor or the prop will come out of the water and "cavitate" (not sure if this is the correct term for this). His O/B motor is a 2005 Suzuki 6hp 4 stroke model#DF6LK5. It's a 20 in. shaft which I believe is Suzuki's "long shaft". Their "short shaft" is 15".
I have looked at several CD Ty Weekenders and sailed one other one. No one ever mentioned this as an issue. I also looked on this site to see if the issue had been addressed. I am not very computer literate but I could not find a discussion of this issue.
My concern is this. Please remember I am a true "tadpole". I was taught that when away from a dock or mooring you must ALWAYS have some means of propulsion/steerage, whether motor power or sail power. If you leave the dock under power, before cutting the engine, you must raise the sails (at least one - preferably the jib). Then cut the engine. In this way, if there is a problem with the sail, you have steerage and do not have to worry about trying to start the engine. When returning, the same principle in reverse. Before lowering sails, start the engine. Then lower sails.
If I must turn off this Suzuki 2005 6hp 4 stroke BEFORE going forward to hank on the jib, that seems like it could be a problem for a "tadpole".
Two questions:
1. Is anyone aware of this issue on other CD Ty Weekenders
2. Any ideas of a "work around"
So, bottom line, have others experienced this issue and, if so, what are solutions
Thanks in advance and again my apologies for cluttering up this board with my silly and amateurish questions.
I am very grateful for everyones patience, understanding and assistance.
