Cape Dory Poweryacht 30
Paul M. Fitzgerald
Plymouth Massachusetts
Post by Paul M. Fitzgerald »
Have a fuel problem. More fuel is being used from the starboard tank. Both tanks were full prior to last trip and when refueling the port tank was near full and the starboard tank 1/4 full. After fillup it is clear that the starboard tank is emptying more quickly :?:
pfitz
Oswego John
CD Poweryacht
Post by Oswego John »
Hi Paul,
I'm not familiar with your model vessel , so I have to ask whether it is a single or twin screw?
Paul M. Fitzgerald
Capedory 30 Poweryacht
We have twin Volvo Penta Diesel engines TAMD41B
pfitz
Joe CD MS 300
Post by Joe CD MS 300 »
In my limited experience with twin screw power boats, the tanks and engines were plumbed so that the engines could run off either or both tanks with an interconnect between the two tanks. Is there any type of interconnect between the two tanks that should be closed? We had this issue on a charter. If I'm remembering correctly the line between the two tanks was open, while the line from one of the tanks was partially closed.
jefff
Post subject: Cape Dory Poweryacht 30
Post by jefff »
Maybe the return is only going to the port tank
Jeff Funston
bilofsky
Location: CD 30 Flybridge "Golden Phoenix" on San Francisco Bay
Post by bilofsky »
This happened to me once. There are valves on the aft bulkhead of the engine room that control the diesel feeds and returns. I think maybe a mechanic serviced the engine and for some reason moved a valve. Check that the valves on each side are open and the crossovers are closed.
