Cape Dory Poweryacht 30
Plymouth Massachusetts
Have a fuel problem. More fuel is being used from the starboard tank. Both tanks were full prior to last trip and when refueling the port tank was near full and the starboard tank 1/4 full. After fillup it is clear that the starboard tank is emptying more quickly
pfitz
CD Poweryacht
Hi Paul,
I'm not familiar with your model vessel , so I have to ask whether it is a single or twin screw?
- Joe CD MS 300
In my limited experience with twin screw power boats, the tanks and engines were plumbed so that the engines could run off either or both tanks with an interconnect between the two tanks. Is there any type of interconnect between the two tanks that should be closed? We had this issue on a charter. If I'm remembering correctly the line between the two tanks was open, while the line from one of the tanks was partially closed.
