Water under bildge
Water under bildge
I think I have water under my bildge floor and in the Keel. I have a capedory 28 1974. Should I grind out the Bildge floor and see how big the void is? Does anyone know how big the void is under the bildge floor?
FLYING CIRCUS
Water under bilge
Hi John:
I'm not sure just where you suspect the water is coming from. The lead ballast is encapsulated in the keel. There shouldn't be any voids in the encapsulation, but there may be a manufacturing flaw that left one on your boat.
There is no void under the sump (deep part) of your bilge, that's just solid fiberglass.
I'd be certain to eliminate all other possibilities before grinding the hull.
Do a search on this website for "water in bilge", you'll discover a lot of hints and suggestions.
Good Luck,
Tony Jeske
CD-28 #365
NO REGRETS
San Diego
Good Luck,
Tony Jeske
CD-28 #365
NO REGRETS
San Diego
I have a CD 28/77 the only place I found some voids and water in the bilge area was from the area nearest the rudder. There was some weeping from the fairing at the rudder attachment to the keel. I put some epoxy putty from out side,faired,painted and have had no problems for 7 years. Next time your boat is out of the water,Look on the outside,in an area nearest the bilge, and see if there any moisture on the surface.
